iLLuSioN
Home
1C80-0010-8001-0000-5466-9470-7384
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM
NT-SPTI used
Nero Version: 7.0.5.4
Internal Version: 7, 0, 5, 4
Recorder: <LITE-ON DVDRW SOHW-1633S>Version: BPSA - HA 1 TA 0 - 7.0.5.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <LITE-ON DVDRW SOHW-1633S>Version: BPSA - HA 1 TA 0 - 7.0.5.4
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON DVDRW SOHW-1633S atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD800JD-60LUA0 atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
LITE-ON DVDRW SOHW-1633S E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1013MB (1037744kB)
Free physical memory: 189MB (193828kB)
Memory in use : 81 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
27.9.2010
ISO compilation
5:45:17 AM #1 Text 0 File Isodoc.cpp, Line 6414
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
5:45:17 AM #2 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 262144KB of Memory
5:45:17 AM #3 Text 0 File Reader.cpp, Line 124
Reader running
5:45:17 AM #4 Text 0 File Writer.cpp, Line 113
Writer E: LITE-ON DVDRW SOHW-1633S running
5:45:17 AM #5 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
5:45:17 AM #6 Text 0 File Burncd.cpp, Line 3341
Turn on Disc-At-Once, using DVD media
5:45:17 AM #7 Text 0 File DlgWaitCD.cpp, Line 288
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2142639 (476:08.39, 4184MB)
5:45:17 AM #8 Text 0 File DlgWaitCD.cpp, Line 300
Write in overburning mode: NO (enabled: CD)
5:45:17 AM #9 Text 0 File DlgWaitCD.cpp, Line 2699
Recorder: LITE-ON DVDRW SOHW-1633S, Media type: DVD-R
Disc Manufacturer: PRINCO - RGM1
Disc Application Code: 64, Disc Physical Code: 193
5:45:17 AM #10 Text 0 File DlgWaitCD.cpp, Line 472
>>> Protocol of DlgWaitCD activities: <<<
5:45:17 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2142640 (2142640) = #2142640/476:8.40
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2142640 blocks [E: LITE-ON DVDRW SOHW-1633S]
5:45:17 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [E: LITE-ON DVDRW SOHW-1633S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4388126720, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2142640 | lead-out | 1 | 0x41 | 0x00
5:45:17 AM #13 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
5:45:17 AM #14 Text 0 File SCSIPassThrough.cpp, Line 84
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
5:45:17 AM #15 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
5:45:17 AM #16 Text 0 File Burncd.cpp, Line 4175
Cache writing successful.
5:45:17 AM #17 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
5:45:17 AM #18 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 8x (11,080 KB/s)
5:45:17 AM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
5:45:17 AM #20 Text 0 File DVDR.cpp, Line 2699
Recording mode: Sequential Recording Mode for Multisession
5:45:17 AM #21 Text 0 File DVDR.cpp, Line 2855
Start write address at LBA 0
DVD high compatibility mode: Yes
5:45:17 AM #22 Text 0 File Cdrdrv.cpp, Line 8663
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
5:59:24 AM #23 Text 0 File WriterStatus.cpp, Line 116
<E: LITE-ON DVDRW SOHW-1633S> start writing Lead-Out at LBA 2142640 (20B1B0h), length 0 blocks
5:59:24 AM #24 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
5:59:24 AM #25 Text 0 File DVDR.cpp, Line 3095
EndDAO: Last written address was 2142639
5:59:55 AM #26 Phase 133 File dlgbrnst.cpp, Line 1730
Writing short lead-out
6:00:48 AM #27 SPTI -1080 File SCSIPassThrough.cpp, Line 290
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x3A
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A
Buffer x0571e200: Len x20
6:00:48 AM #28 CDR -1080 File ThreadedTransferInterface.cpp, Line 1937
Disc not present
6:00:48 AM #29 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1937
Could not perform end of Disc-at-once
6:00:48 AM #30 Text 0 File DVDR.cpp, Line 3095
EndDAO: Last written address was -1
6:00:48 AM #31 CDR -201 File WriterStatus.cpp, Line 167
Invalid write state
6:00:48 AM #32 TRANSFER -24 File WriterStatus.cpp, Line 167
6:00:48 AM #33 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 8x (11,080 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 10/28/2003 5:02:00 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
